  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol ok, you in?
Yeah I can put grease all though my hair and talk in a brazzillian accent, the way a real sleazy car salesman should, "Oh yes you defointaly need a whole lot more 'orses can I interest you in a fine r34 gtr?"
