  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I wasnt aloud to put the kit in, dad got cold feet and thought i would die, so im gonna have to wait till he cools down a bit, i took him for a strap last night though and he absolutely loves it, he's just pissed cause its quicker then his ute!
