Dun forget zip ties, platium brought along the MOTHER of ll zip ties last night, could be used for fixing those big dumptrucks they use at open cut mines, Uclids, this thing was MASSIVE!
oh and a hairpin, an old pair of nylons and 1.2 grams of fine grain sand
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
bit expensive though.. and soon as the cops figure out what they are, all over red rover.
They'll probably just make a law "any numberplate cover is illegal" and then that is $500 to waste :rofl:
and I suppose that sticking one of your legs in front of your rear plate when on a bike IS legal? And I suppose parralell parking is illegal? Oh well we'd better behave. :rofl::mad:
edit: ok now I understand. my bad. :rofl:
They'll probably just make a law "any numberplate cover is illegal" and then that is $500 to waste :mad:
I was thinking the same thing.... I could so see them doing that
it still wouldn't save you with a cop tailing you :mad:
i remember in VIC as it had turned into the revenue state, they upped the laws on "driving with a dirty or obscured numberplate" up from 1point to 3points and from $50 or something fine to $200. All just so they could put more fixed revenue cameras all over the place.
God Victoria was beginning to suck!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
