  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Didnt u go on the cruise matt?
i was going to but had too many commitements this wkend
My cars handling like a 19 yr old virgin, real smooth and controlled.
Fulcrum is great, got full whiteline kit + Strut brace and im going back next week so they can alter my front shocks to raise them higher and im also getting front camber kit
pred, hows your car? last i remember it was finally being painted one colour again
no idea .. its still there.. technically it was meant to be ready end of last week, but surprisingly i didn't hear from them. No hurry, as I am pretty poor right now and when i have it back i gotta pay the $1300 for it and i only just have that much.
Might ring em at the end of this week if i can be bothered.. lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
