  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Didnt u go on the cruise matt?
i was going to but had too many commitements this wkend
My cars handling like a 19 yr old virgin, real smooth and controlled.
Fulcrum is great, got full whiteline kit + Strut brace and im going back next week so they can alter my front shocks to raise them higher and im also getting front camber kit
pred, hows your car? last i remember it was finally being painted one colour again
no idea .. its still there.. technically it was meant to be ready end of last week, but surprisingly i didn't hear from them. No hurry, as I am pretty poor right now and when i have it back i gotta pay the $1300 for it and i only just have that much.
Might ring em at the end of this week if i can be bothered.. lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
