ok we were playing pool...n some ppl were watching the big telly there. then the footy ended n we decided to go watch them play pool.
nick was standing a little too close to another table n the woman bumped into him...without saying could you please move...
so her boyfriend or whatever decided to be a brave man and pick on nick out of like 10 other guys there n said "if you wanna stand here watch where you're going"
but we decided to let it go anyway...
then some of us decided to go back to the telly n afterwards, rozz (neil's bro) told us he saw the woman give him the finger....really weird
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah.. i've been thru it b4 for 8 weeks last year :).. i'd like to have it back, but when it comes back i have to get the major service done - so more $$$ before i can really drive it properly anyhow.
i'll probably just take it to one thursday night, then it will sit there until i can afford hte major service :)
ok...then we proceeded to park road for coffee...n us asians in the group were at one end of the table with aaron n his friend.
so one of our friend, kelly, decided to light up a ciggie. the table behind here, 4 huge ppl, again, with one guy in the group, decided to lay shit on us. calling us china men n all. they told us to go somewhere else if we wanted to smoke n all that.
long story short, they were just bloody racists n probably idiots too. the huge lady who started it all asked if clown had looked in the mirror recently cos he looked like a bloody clown.
oh yea the guy was challenging john to a fight too...but at a distance of course...what did he think if john went over he'd be alone?? man some guys are stupid
shit....sounds like an eventfull night....you sure one of you didn't have a "champion street fighter" t-shirt on or something :)
i was thinking the same thing...like the hormonal levels were really high last night...but must have been the long weekend....weirdos tend to come out when there's a holiday...n besides...those racists were welsh...like tourists man
Ah a boostcruising cruise.................to me boostcruising is 17 year olds in excels and lancers with chrome wheels and an annoying exhaust.
Tell me about it pred.....ive spent so much $$$ it scares me to think of what it total's to and ive only owned the car since oct last year
any idea of the total??
racists = pathetic insecure losers
shoulda told them "fu(k off home you limey tools" :)
hmmmm...would that be considered racist.....
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
