  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
u're hardcore warwick....
so by the looks of things...no salt n pepper squid for u later??
might be able to sneak out after this thursdays cruise for some S&P squid if you guys are up for it :)
Glad i stayed last thursday though....eventually got to trash my tyres :)
morning Glenn....morning for you that is :)
yeah ... i did.... was working on Nick's and Neil's car yesterday.
when i was flushing Nick's brakes... i was shocked @ the amount of air trapped inside previously.
and the radiator was only half full.
sigh.....
i knew u had it in u to trash those tyres...heh
hmmm...if this week's cruise ends early i might be able to go for some supper...i got school next fri...
yer.. my brakes are ****ed.. need a flush too in the least. Never been done since i got it, could be the reason my brake performance is getting worse and worse as i think the pads are ok.
may be making use of your facilities in a couple of weeks, and some of your brain :)
have to ask this...are u famous in melbourne??
Famous? why you ask that? I know most of the melb SAU crew from when i lived down there
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
