nice nice.. with buckets more torque than the rb too?
james: stop teasing us with events from your life and then not spilling.. yer, life can suck i agree.
hmm, damn.. i think i may have found *the* next car.. for $14k i can get a twin turbo car w/ 210kw that has ****ing everything, and looks kinda neato.. and one day i can stick a big **** off turbo on it, and it will do 12's easy
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
