  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
This is My all time favorite. :thumbsup:
A few weeks ago in a movie theatre in Melbourne a person sat on something
that was poking out of one of the seats. When she got up to
see what it was she found a needle sticking out of the seat with a note attached saying "You have just been infected by HIV". The Disease control Centre in Melbourne reports many similar incidents have occurred in many other Australian cities recently. All tested needles are HIV Positive. The Center also reports that needles have been found in the cash dispensers in ATMs. We ask everyone to use extreme caution when faced with this kind of situation. All
public chairs/seats should be inspected with vigilance and caution before use.17 people have been tested positive in the Western suburbs alone in the last 2 months!!! A careful visual inspection should be enough. In addition they ask that each! Of you pass this message along to all members of your family and your friends of the potential danger. We all have to be careful at public places!
This is very important. Just think about saving a life of someone even you don't know by forwarding this message. Please, take a few seconds of your time to pass it along.
Australian Red Cross Blood Service
Ph: (08) 94212877
Fax: (08) 94212366
e-mail: [email protected]
,mailto:[email protected]>
damn friggin ISA server needs reboot every friggin second, means gotta kick everyone off the sql server which equals a lot of very pissed off people, this will be the FRIGGIN 4th time I have had to reboot the bastard!! DAMN MICRO$OFT CRAP!!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
