  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hehe pred, i just like the feeling of being on top of things and not having debt to worry about. I gotta spend as much $$$ as that will be gone when i eventually buy a house so i gotta have my fun now.
I got my alloy bush/spacer things fitted today, they are great. Really firms up the rear end and i feel safer going around a corner just that bit faster. The car also squats down good when i launch it too
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
