  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
almost mj, almost!
so did u say that gavin will also do your camgear?
i am keen to pull off my timing belt cover and see the condition of hte belt (so i know how much longer i need to replace it.. like another 5000km could be fine, or like NOW.. stop driving it completely, etc). I am thinking maybe if i get that far, i will just install the camgear.. then take it to gavin to adjust and do a full dyno tune.
Nah i wont get gavin to do my cam gear as its too much of a pain in the ass. I goto APC to use the dyno. Im thinking does it really need a dyno tune, ive searched the forums and it seems everyone with a camgear puts -4 and gets good results. So maybe if we just put it on and set it to -4 it should be fine??
yer, that is what i was going to put on.. but leave cover off for later tuning on dyno as required.
if you want to do it same time, could be a good little project i reckon.. there is a good thread in forced induction on how to do it.
bed? thats a little extreme jamez.. although i must say i don't feel much better..
yer, i understand .. and I am cautious myself. if i fried my engine i would be very up a creek.
But reading the thread, and all the comments from people (some of which don't sound too much experienced with doing mechanicals than me) who did it themselves, i think its doable. I have the tools, thats easy. It basically sounds like, remove fan and shroud (and x-over fmic pipe in my case).. mark CAS position relative to cover and remove.. remove cover.. behind should be the marks.. one at 10oclock inlet side, and 2oclock exhaust .. rotate crank to TDC, this should be where the built-in belt marks align with these marks.
unbolt stock gear.. pull off.. bolt on new gear, bolt on.
do all up..
i am confident now reading all that.
yup, i better go order mine too.. without a gear could be kinda hard to do. Wanting to do it about 2 weeks time. IF we get to a point where we go "hmm, looking too difficult" i guess we give up and put it all back together. Nothing lost, knowledge gained!
meant to make a nice difference.. better off peak power, and helps the turbo to spool quicker and harder
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
