  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
The Golden Week is a collection of four national holidays within seven days. In combination with well placed weekends, the Golden Week becomes one of Japan's three busiest holiday seasons, besides New Year and the Obon week (July/August)
The national holidays making up the Golden Week are:
April 29
Green Day (Midori no hi):
April 29 used to be the birthday of Emperor Showa who died in the year 1989. After his death, the day was changed into a national holiday for environment and nature since the emperor loved nature.
May 3
Constitution Day (Kenpo kinenbi):
On this day in 1947, the new post war constitution was put into effect.
May 4
"Between Day" (Kokumin no kyujitsu):
A recently introduced, national holiday to make the Golden Week a continuous holiday.
May 5
Children's Day (Kodomo no hi):
The Boy's Festival (Tango no Sekku) is celebrated on this day. Families pray for the health and future success of their sons by hanging up carp streamers and displaying samurai dolls, both symbolizing strength, power and success in life. The Girl's Festival, by the way, is celebrated on March 3.
More information about this holiday period can be found at http://www.japan-guide.com/e/e2282
yer, depends if they close, or are open like for a day.
Not sure even whether he holds his own stock, or just gets it from suppliers on each order.. if that is the case, then most places will be closed - resulting in delay
shipping for 1x camgear and 1x cap is like $43! just for those items?! thats a bit expensive for the shipping.. especially considering customs will slug too when it gets here
Pred, you should incur no taxes/duties as it will be less than $400.
Oh yeah, I'm gunna hassle you about that fuel pump install soon *Cheesy Grin*
hehe.. well good to hear your car is going to be back soon and all is not lost!
hehe, yer, will be happy to do that still.. i went into fuel pumps having no idea just "that doesnt sound too difficult i think i can do that" and it all worked out fine, so camgear should be same.
can do it same day maybe.. anyhow, decide later.. i am out..
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
