  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cool, thanks guys
mite give it a go this week
so i need to look for some plastic primer?, does the actuall paint have to be for plastic or it doesnt matter
Helps if it is, but not necessary.
As long as you have sanded back the bits you want to paint and you use a good surface primer it should come up schmicko :)
