yep should be ok...i'll talk more to glenn n finalise the stuff up and send u an sms later ok?
i might meet you at like coronation shell or sumthing like that otherwise u'd just have to drive here n then back again
I am at Jill's though, at Sinnamon Park, so I have to drive past your place anyway.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yup.....   should be good... all the local nissan owners are coming down... should be a great day :wassup:
Sweet, the more the merrier. there should be a few of us, there is a lot of interest, and we have a good core group now that turn up to most things. Should be a good day, its been ages since I headed up the sunshine coast.
