  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
thats why you own one, that way you never have to sit in the back :)! Was it a 32 or 33? 32's back window comes down really quick but the 33's aren't to bad, on the other hand maybe your just a giant haha.
wat did you do to the sister? geez the parents know youve been fooling around with their daughter and her sister already hates you, sounds like you have definately got your work cut out for you haha GOOD LUCK
