  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Glennnnnnnn
how's the new job treating you?
noticed a distinct forum absence from you today.....
warky~~~~
new job is good. going thru intensive training now becos the person i'm replacing is leaving in 3 weeks.
and yeah.... i dun get my comp till she leaves..... sigh....
tell us how you really feel about them Chris......:)
Okay
I am so sick of these rich bitches who have never had to work a day in their life, coz daddy has paid for everything.
They have no ambition in life apart from marrying somebody who is already successful.
They are not interested unless you have a healthy bank account. They are not interested in anyone who is building their future coz they don't want to have to wait around till you do that.
Can you tell that I don't like them?
Okay
hmmmm...yeah...I think I'm getting the picture
and btw....I share your sentiments
