  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
If I even think about this any more it will be taking precious seconds of my life that I'll never get back.
too hot. Pfft.
Did you find out about the "quality" Cb's we're sposed to be getting? Coz All I'm doing on Saturday is chasing down all the rattles in my car and perhaps putting in the "skyline" light in the back of the car. And In the last 2 days you've had I've changed nothing on my car. :D
too hot.  Pfft.
still waiting for dodgy man to call.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
