  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
but they don't have the good stuff like frozen pizzas, icecream, mini dim sims, party pies, all the good stuff :) there were some funny moments .. we used to walk home with about 4-5 shopping bags just of rubbish to eat at 3am in the morning. cook up some strange feasts.. lol
and 7/11 or the servos cost a damn fortune :)
Thanks adrian, i was fairly impressed too. I posted the Dyno sheets in my gallery.
Was hoping you and gord would be there 2nite, still a good nite tho, i cut it short once they started parking in the valley there to hang out.
Mt nebo run was crazy, we flew up there. Chilled for like 5mins then FLEW back down. I was behind R33 GTR dont know who but i was right there behind him the whole way :)
Was good to test the car aswell as my driving skills.
definitely a good rush..
my car wasn't really up to scratch last time (the 33 that is). its got a front stut now.. but the brakes still need attending to..
I was hoping to do that this weekend, but not looking like i am going to have the car to do it ..
There is more power there going by your AFR's...
Regardless of what Romanos say (who are renowned for liking rich tunes), AFR's in the 10's (and lower) are not conducive to good power...
You'll find that up high in the revs the AFR's are below 10:1... Most WBO2 sensors flat line at 10:1, as can be seen on your graph...
Ahh Nebo... So you didn't go all the way to the T?
Now you know how a real SAUQLD cruise goes...
Yeh i can feel it has alot more, i dont really like the romanos but seeing its just a read out and not a tune it didnt bother me.
Cant wait to chuck in all those puters and intercooler and see how good she puts out then (hehe
I did the whole nebo cruise then back into the valley but jetted from there. They all went to a restuarant or something?
nah 1994 s1 :)
I still stand by my theory that the auto transmission pampers the engine majority of the time meaning the engine has an easy life.. but when need be still has the same power as manual
its because auto always keeps you in the highest gear and lowest rpm when not gunning it, so the engine stays healthy
or something like that
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
