  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah james....boost comes on quicker and engine seems to rev a lot freeer
getting some popping in the upper rev range now, i think it's over-fueling (I hope, coz i don't really know what pinging sounds like), so the SAFC prolly needs a re-tune
I am hoping to get a cooler in the next few weeks (sshhh...don't tell the missus), so might hold of on the re-tune till then to save having to do it twice
Wouldn't mind getting someone with an experienced ear to come for a ride in the meantime, just to reassure me that there is no detonation though
mmm i was under the impression that when ur engine started pinging the check engine light came on, or mabey that only happens with a pfc,
I have NFI
the same thing (popping noises in the upper rev range) happened when I changed from a pod filter to a Blitz panel in the factory box....went back to the pod and it was gone....pretty sure it's the SAFC tune
i might go for a run up mt tamborine or mt nebo-glorious just feel the needs for the corners and its a lovely day. I dont have a mother so I just got another day off work :)
/me dances.
hmm car all clean and the oils are right, just need tog et this 100k service done next month, rego this month :)
perhaps get adrian or mj to have a fiddle with your safc settings, perhaps make sure its safe for the time being?
yeah...might call on hero boy to have a look next time he is about....don't have any dyno info with AFR's though so it would be stabbing in the dark a bit...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
