Scott - fine fine, getting ready to rob a bank, but fine :D
Adrian - nearly half way though uploading full ver of that thing I PM you bout, uploading 1.3Gb at 10k/sec takes ages!! :D
Gordo - 8:30am but i gotta leave late so meet you all there :mad:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
WHAT WHAT WHAT,!?!?!?!?!?!
Unseen footage!!!!!!
You coming to dyno day on saturday!?!?!?
if not i can stop on the way in or out and grab them :D
i'm going to rocky this wkend.
the unseen footages are actually of some of the pixs which neil did not upload onto the tkrazy website.... and maybe some videos as well which he did not post up :D
you may or may not have seen them b4 :wassup:
i won't be to the dyno till midday.. not even sure whether i will put a car on there. r31 has curious factor but maybe power loss to ground due to grinded diff.. r33 seems sluggish and needs a full proper tune - i know it'll only put out a seesaw probably at the moment.
ho hum. .maybe i better go read that thread
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
