  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
james: oh ok, coolies you got it in. Yeah, its a bit hard to judge. But a torch does wonders.
That jar thing is a ****er.. but i worked how to do it much easier later.
Luckily the fuel guage sender is a bit further away. They are still inaccurate as crap anyhow
the reason i ask... i am after a fancy knob for my auto , and wondering one may obtain a fancy knob for an auto
Negative... I have seen them... I may be able to dig up a pic... But yeah... It depends on how the shift lock works and whether it has an OD / Hold button...
dang.. i know how i can do it. I can remove the big shifter, splice the wires for the "power" button (yes its a "power" button on an r31..wee), and squirrel it away to a switch somewhere else. And just have it so its always engaged and you just bang it up and down.
The main problem is finding a manual knob with a circumference that will fit over the auto stick.
hmmm.. i am on a quest for knob! :P
i'm starting to do it up a bit on a cheap-ass-budget.. thought why not.. Not much more i want to do to the R33 styling wise.
hey james.. does it make that cool sucking noise when you turn on the ignition and its priming up. I love that.
