  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
wasn't there one for sale in the FS forum last week?
All EFI cars have 02 sensors... Most are only NB (Narrow Band)... They are only good for measuring stoichiometric mixtures (14.7:1)
A WB O2 sensor can measure from 10:1 thru to 20:1 or so... Some european cars use them factory... They aren't cheap and are often found shoved up the rear of cars on a dyno...
Pretty sure it was a wide band....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
