  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh.. guess that doesn't make sense either :thumbsup: i was saying.. when i go to sell my car soon (as that is probably what is happening).. nobody wants to pay about $23k for a nicely modified R33.. they all want to pay as little as possible, and reckon a GTS-T in good condition and pretty well cared for (for the most part) with $10k of mods should only be worth $17k.. ok its not worth $10k more, but it is worth a little more than $17k.
I tried to sell it in melbourne last year and the amount of people trying to beat me down to low figures was stupid.. considering the amount of modiifcations on it (ok, true no big turbo, etc but pretty much everything else).
pissed me off..
people like to throw money away obviously.. modifying a car from scratch costs soo much..
i bought mine with a nice selection of mods because i knew modding it from scratch would cost me 2x or 3x the price and i'd never get it back. I've done a few things, but the stuff i got on there i'd never bother changing anyhow really.
hence why i may have to consider returning it to stock to sell at a cheap price.. even though to me a stock skyline is yawn territory :thumbsup:
anyhow, i was asking what james had as stock as this may help my plan.. but he has gone..
yeah, i just bought mine and to be honest i was prepared to pay more for a un modifed one,
reason being you dont know how the modified one has been hammered prior to u buying it
yup... usually the impression is modified car = been fanged out hard...
also gives the uncertainty whether or not its been in an accident... (new front bar, etc, etc)
busy donwloading
its so ur thing.. :thumbsup:
hhmmm...
to me if a car is heavily modified if anything will go wrong it would have under stress already :thumbsup: If it brakes under stress, it would have already broke by now..but in unmodified form who knows how it will take to the extra power. On road stress testing ! :)
And you never know whether the "stock" car you bought had 50 mods in japan and exactly the same stuff was done to it over there, then returned to stock either. Plenty would have been.
i just sold (about 10 mins ago)
my stock cooler and airbox,
i still got a series 1 boot wing?
u can check the obvious tho,
always good to look at bolts and nuts in places like by the turbo and intercooler to see if they have been taken off.
..and who says stock cars aren't thrashed either?
if anything, you know the guy who has modified the car is an enthusiast, who probably has cared about the car and spent more keeping it all running nicely (extra time in the shop, getting regular tunes), more so than the guy who just bought it and just thrashed it to the shops each day.. so when it had done xx,xxx km he could trade it in for something else?
Would you buy a company or family car over here? even though of course its going to be in "stock" form?
:thumbsup:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
