  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
photographer called me tonight, he was supposed to call me on wed to let me know if he was definately coming and organise a time. So i didnt bother cleaning the car today..... i have so much shit to do tonight its not funny its very gay infact.
