  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
looks like a bong at first glance but its a beer..... got it form qld transport website i think, drink driving thing..
i got a daikin clutch, pretty good tho im not putting massive power thru it. its a single hd organic. cost 480 + fitting
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
