go front strut bar and sway bars.... front and back.... even with stand springs and shocks, you will still easily out manevour most cars....
you trying to get me broke?! :)
you keep giving me ideas to add more mods to the car, probably end up doing a RB25DET engine transplant and a T88 and nos.... :headspin:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh but dont forget exhaust...will be lower than your standard one
not really benny boy... max piping size for NA should only be 2.25 inch catback and muffler size is almost same as stock....
you go anything more than 2.25, you will lose back pressure.... less torqy....
ME giving you ideas?? :confused:
i would go handling first..... no point spending thousands to squeeze a few more KWs outa the car...
awesome handling makes you a better driver...
I've got a twin cannister 3.5" exhaust sitting in the garage :)
ya, I'm going for tyres first Glenn costing me a butt load too.... almost half my uni tuition.
can sometimes even be just be the gaskets or rubber mountings.. gaskets are like $2.50 to replace
where can i get this checked out? at a normal garage???
yup.. not cheap..
krawler: no.. they're just spring and shock setup.. i sold my old set for $200, they were sitting around for ages
Doesnt coil over simply mean the coil is over the shock?
Meaning that most cars are coil over factory.. The term coil over is normally targetting adjustable gear though.
i know... It was on the NA, but got it taken off for compliancing.. and power loss.
now i'm stuck with a stupid rattle.
get 2 jacks and a creepboard.... rip out the heat shield....
if not the heat shield... hammer the resonator gently to check for rattling...
i think the difference is.. with coilovers, the shock is actually welded to the bottom of the spring, and they are basically one unit and cannot be separated. Most things can be adjustable.
With a spring and shock setup the springs and shocks can be separated and changed independently. In that setup you can adjust the shock, but not the actually spring height or anything like that.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
