  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
they carded it for a business? lol .. thanks for picking it up too.
camgear is somewhere on a plane from japan to sydney.. its going to get here about 3 days late i think for gavin to put it on during timing belt, etc.. so i'm going to have MJ's camgear. When it does actually arrive, he has mine. All worked out :)
Well it worked out for you but not fo me :)
Oh my Chris you really have dropped off the pace somewhat, must mean you got a life, DAMN YOU!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
Hmmmmmmmm having Ben move in will mean I will be able to catch up to him, as I only have a work laptop which no one uses but me atm, as it has certain company info, so it is for my use only, meaning Benny boy will be without net access until I can get another computer organised :) looks like it is going to take a while!
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
If you want to call her that :)
I never cared about post counts anyway, they mean absolutely nothing
chaos 3930
Cyrice 2897
Genesis® 2655
BelGarion 2485
Lazy-Bastard 2353
strutto 2274
predator 2082
SmoothLine 1984
Nexus9 1937
TeamKrazy 1439
I don't even get a mention! Damn me and my 6 months with no pc!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
