  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
an idle mind in the devils workshop
i could start bringing some girls, but none of them are asian. Well could bring ex to make her geolous but not worth the all the shit.
I dont know what it is with skylines and asian women
goes together like beer and pretzels
