  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
All my shit gets caught in customs, then i have to go argue with some fat lady about the TAX % on turbo products
James: Ok cool, well ill be asking for a ride in it obviously :) Im still throwing up ideas at the moment.
If money permitted ide built my engine with forged internals and all the support systems with Twin HKS 2835 pro's
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
