  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Oh and I forgot to say, apparantly according to DOT I have an Auto only licence, even though it says on my actual licence card that I have a full licence.
I did my driving test in a manual car, I have never owned an auto, just goes to show how crap the DOT is at doing their job properly.
If it was a business they would be broke :rant:
yeh but eug thats a sig....yours was typing :rant: if squizz did edit it, it would say :)
yeah chaos if I catch him doing it again I am going to catch up with him & break his typing fingers lol then he is no use to no one :flamed:
:jk:
