  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nite mikey
yeh erin its not so much the start that worries me..im usually stuffed when i get home its just who i work with...
The joys of a new job :rant: Even I htought to myself "have I done the right thing, i hate this place" in the second day of my new job, but I knew this move was for the best in many ways. Money, Happiness, workload, Sinbad's benefit. But for you, you've got like a double wammy, no family, no familiar surroundings, your totally out of your comfort zone in a new house and a new job. At least give it a month and then decide :)
I hated who I worked with in my last job but I stuck it out for 8 months to see if it would improve, but I just wasn't strong enough to do it anymore. You could cut the air with a knife some days. It was shocking
I don't miss the people I work with at all. To be honest, my last job was just something to put me in to permanent work. Before that i was a temp getting extended for 3 months at a time. I did that for 3 years and just wanted a permanent job that I knew would be there tomorrow for me.
I know this new job is the best thing that could happen. Only bad thing is, I actually have to do work to get my money now. Sucks :rant: Before hand I just did a bit of data entry and sat on a phone. Now theres like deadlines and monthly reports and marketing and rosters and payroll and log books and training and the list goes on!
yeah but you enjoy this job more erin so its all worth it.
im a contractor so some weeks i work 32 hours and other weeks i work 44 hour weeks,it depends thats the only part that i dont like about my job, but 32 hours a week is still plenty to live on
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
