  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I was going to say that I feel for you having to read stuff like this all day. But now I hope that all this metrosexuality taints your brain and you start buying fashion items and exfoliators, and mud baths instead of car mods.
Gordon
"It takes so little to groom. But you never know where you leave an impression that will stick with you forever. So daily grooming is important."
Darren
"Grooming is important as it is basic courtesy to look your best when you meet people, be it at social gatherings or business dinners or other occasions."
Sky
"I am not born with good look, so I need grooming to bring out the best in me! by looking good you will feel more confidence of yourself in whatever things you are doing."
Shane
"i want to look presentable to everyone."
Gui Chung Yee
"it brings out the best in me at all times."
Kenneth Soh
"presentation of one personality is a critical success in life. Making the best out of oneself."
Greg Tay
"its not just the clothes that maketh a man. Good groomong tells the world that you have arrived!"
http://proxy.espn.go.com/chat/sportsnation...iz?event_id=418
^^^ metrosexual test. I got "You answered 0 questions correctly out of a possible 12 questions."
This is the Scoring:
12 correct answers: One hot brother!
9-11 correct: Call your fam and friends -- you're a metro!
6-8 correct: Keep it up, you have serious potential!
3-4 correct: Go buy the latest GQ and study up!
0-2 correct: You're a lost cause.
Scoring:
You answered 6 questions correctly out of a possible 12 questions.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
