  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ta, wados.
was thinkin of using a injector outta a civic or something with a simple 555 timer circuit to get the duty cycle happening and just hook a hoobs pressure switch up to the circuit to make it kick in at 10psi (once in gonna run 16-18psi :rant:) than when i need more water just turn the pot to up the duty cycle :rant: great working in electronics/mechanical shop :rant: they sussed out all new silicon piping for my engine bay today lol cause the boss was away :( now just need the money :D
