  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I am quite sure everyone else has gone too bed or still out and about , I know what Ben's / Cyrus's secret is MMMMWWUUUHAHAHAHA
Yeah talk about team Dodge on his BOV , make sure you get those pics Ben before he takes it off !!@^*#$(#&*#^@&*@(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
