  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
The stock BOV IS FREAKIN LOUD! And yeah with that setup it did idle properly, just need a bit of pressure buildup in the bov for some reason, dunno why, but yeah took it off because instead of getting ~450kms to a tank of petrol I was getting ~250kms, lots of backfiring and just ran really roughly and super hell rich, hence the high fuel consumption.
So put it all back, miss the PPPPSSSSSSSSSHHHHHHHHHHHHTTTTTTTTTTTT though :)
Why dont you buy a non-stock bov then?? :).... 250kms is rediculous!!
WA is full of dyno queens and ricers :)
i have seen more riced up hondas than on lygon street in vic
oh and it is really easy for mining jobs in particular at the moment.. got 5 openings for drivers.. close over 50k a year package with medical dental and super... shift work though and 12 hr days
Why because i want an exhaust first, ebc then maybe might think about atmo bov, might, love that sound though, really miss it, prolly get a pod first, then the sound of the stock bov will actually be hearable from either the pod or big zaust :)
Ummm when can I start? 50k WHOLY CRAP!
:Pres-hit:
