  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Ok lets put it this way guys ....
Would you be pissed off if your girlfriend was buying an R34?
Cos my boyfriend is being hella negative in a time im really happy and wondering why im getting pissed off :)
That is the story.
Really if you are single and can be tight with your money, a mate of mine who has been workin in the blair athol mine, central qld, he has been workin there for 3 yrs and has about $150k saved up in the bank, he's going to try to retire in 3 years with ~$500k, buy several houses and live off them.
But yeah no life and have to deal with other miners, who are normally drunks, no offense!
not anymore they are.. come to work with even a trace of alchohol on your blood and its a one way flight home never to come back.. probably why they get drunk when they are home :throwup:
That is the story.
guess what you've pissed me off now :) i need an r34 before you lol, guess you gotta few years on me hehe. im gonna try get house loan next year near the endding so i can get an r34 and a piece of land to build shed on with stuff in it to live and get house built up slowly on it :) good having mates in all the feilds :)
Boy goes before the car ever will :)
what happens if u really really love him??? lol
my car would go before my girl cause i dislike my car put me into a tree at 100clicks and spun out an me couple of times to.
but an r34 she would be gone but she said its boardline of liking, she likes chev's :|
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
