hey shane.. how is your car going - any luck with fuel pump?
i had a look at MJ's 040 sunday.. was getting a bit dark so didn't have a chance to get into the fuel tank (and was being a bitch.. always hard to get it open the very first time)
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Something I bookmarked a while back, closest to your's would be 'JW0 Millenium Jade'. But 34?... :confused:
BNR32:
KH2 Gun Grey Metallic
KG1 Jet Silver Metallic
TH1 Dark Blue Pearl
AH3 Red Pearl Metallic
732 Blak Pearl Metallic
326 Crystal White
KL0 Spark Silver Metallic
BNCR33:
AN0 Super Clear Red
BN6 Beep Marine Blue
KH3 Black
KL0 Spark Silver
KN6 Dark Grey
LP2 Midnight Purple
QM1 White
KP4 Sonic Silver
AR1 Super Clear Red 2
BNR34:
TV2 Bayside Blue
QM1 White
KR4 Sonic Silver
KV2 Silver
GV1 Black Pearl
AR2 Active Red
EV1 Lightning Yellow
LV4 Midnight Purple 2
WV2 Sparkling Silver
QX1 White Pearl
LX0 Midnight Purple 3
EY0 Silica Breeze
JW0 Millenium Jade
They are the GTR colours Shane... The non GTR's had a few other colours...
R32 Colours:
KG1 Light grey
TG0 Dark grey
TH1 Dark blue
BJ0 Light blue
AH3 Red
KH6 Cream
326 White
732 Black
R33 Colours:
KL0 Metallic Shiny Silver
1N4 Light grey/silver
1N3 Dark Blue
AN0 Burgundy
KH3 Black
QM1 White
KH2 Dark Grey
DN0 Aqua Blue
BN6 Awesome blue
so DN0 = Aqua Blue, also known as Ice Green, also known as Burnham Green...
Apparently only 300 made in that colour...
hey james, did you 040 come with any pickup of anykind??
matts seemed to just be the pump with just a big mesh under the bottom.. wasn't sure how it would suck from the bottom of the tank from just that?? as it would generally sit to high if just in the stock bracket i would have thought on anything less than 1/2 a tank.
is there another part that is meant to go on the end?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
