  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
gday beau
hrmm the last time i had a good drive was when u were passenger in my car beau
damn that was ages ago :rolleyes:
THAT was a great night , some good driving that night , maybe I should be your navigator when it is complete . :P
i can get a 2nd hand ct26 same as what i got for $150 new compressor and turbine blades i can machine it here at work put it togeather and i got a new bit better turbo :P plus i grind off ct26 and toyota off the turbo and make it look pretty :rolleyes:
think its worth doing?? adding a 50 trim gives around 30rwkw from an video i watched of them modifiing an mr2, but he got 110rwkw stock :| problems there hehe, i got 122rwkw at max 5psi lol stuiped e-clip
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
