  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i want ur r34 laurn HEHEH!!!!!!!!! its to much car for you to handle i dont wanna see you getting hurt so we trade ok, a girly 4banger for a 6. mines got 2 seats :P that adds sex appeal to some :rolleyes:
LOL Luke .... no deal .... but if your ever in WA i'll let ya have a drive :rolleyes:
Thanks James - certainly is!!
well now it looks like i gotta take a trip over there to see some people hehe, catch up with my mate james, and nadines older sister and her bf that gave me shit about wanting a mr2 he owned a damn civic :|
only nissain motor i have driven was a vl turbo and moved it from my drive way to the front lawn so i could move my car :P
James: Most likely yes ..... I know the car well - just gotta test drive it tomorrow night - if thats all good then its all mine ...... in about a month when the owner comes back from Indonesia and ive sold mine.
:P
anyway forums to slow to switch between states - so i'll catch you all later :rolleyes:
yeh the 3sgte is nice :rolleyes: but why didnt they make a car like the silvia with it in it :P they'd probley be more popular for drifting and shit than an sr20 silvia cause the 3sgte is heaps stronger from what i hear. ohwell toyota is lame, wonder what i would be doing if i brought that supra instead. hrmmm
probley 6foot under hehe
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
