  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just to inform you all, Team Shitbox is NOT anything to do with boostcruising at all.
It's a website that andrew has set up from scratch (learnt PHP) and it was his first ever attempt at making a webpage from the ground up. He decided we would get it hosted on the net for people who started team shitbox to participate in a forum.
*I* pay for this website and if any of you have any further derogatory comments to make about the website, it will result in a personal attack warning on who ever comments further. :rofl:
They aren't all shitboxes either. If you want to get pandantic with things, my skyline is part of "team shitbox" and so is Dave's cefiro, so is an 12sec WRX with the plates SHERIF that you may have seen around the traps, so is 16OTU which is an 11.3 sec Gemini who frequents the cruising scene.
why is it called "team shitbox" then :rofl:
wasnt there a crew of people that did actually have shitboxes out there? like $500 crappers.. or in fact like my r31 :rofl:
I'm glad you feel the love gordo. and Btw this has got to be by far the SADDEST converstion we have had on here in a very long time.
nah.. nowhere close.. remember that time when you stuck the gerbil down your pants when i dared you a lollypop and i distributed in kazzaa all over the internet? and you cried, and told your mummy.. and my mummy told your mummy she was a ****??
Wtf? are you serious? If we, as a group of car onwers cannot disscuss another group of car owners openly without you taking offence, then I don't think you should be moderating here...
I think it's shit.
In a box.
That races.
such fragile nerves on here.. i think its a bit poor if you can't openly just speak rubbish without somebody getting their knickers in a knot.
that borders on censorship.. and if we live in a sensored state we may as well go dig Saddam out of jail and make HIM a moderator.
easy....
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
