lol thats a bit hypocritical isnt it gordo
of course :rofl: ... but i want to spend more than the car costs in performance next time.. now thats tough.. lol
Car $10k or under.. rest = engine build.. this thing will be fast.. dang fast
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was just wondering why society frowns upon the devotion of real anorexics, and in saying that I mean the ones with suficcient devotion to starve themselves thin, and yet society proclaims ad good and just the same sort of madness that it takes to be brilliant and churn out straight sevens at university. Was at a graduation ceremony for honours a while ago and the dux of the class had a gpa of 7 which means she didn't get anything but 7's for the whole degree.
In this day and age of obecity I think we should champion Anorexics with the devotion to stick with it, and frown upon the obece that lack the self discipline to get with the program.
thoughts chris.
