  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol. my mate came around with his commodore ute tonight all pumped up about the new vx engine in it, went for a drive and it just has nothing on the skyline! anyway, later we went to get a feed and took my car, gave it a bit and he just turns to me and say "**** i wish my ute went like yours and justins cars!". lol
hahaha.. yeah, gold..
like when u see at the strip all these guys with their newish XR8's, HSV and all of this and exhausts and powerchips and everything else - $$$ ..and still they get low 14's to high 13's at best.
Best to replace the timing belt, I had to replace mine 10000k after I changed it for the 100000k service after the crank case seal let go spraying oil everywhere and on the belt. Gavin said it was best to change it again and I kinda agree.
sh*t that would suck!
..probably a cheap R32.. in auto.. then throw all the drivetrain ..
and get an RB30DET built.. nice bottom end first with forged pistons.. then maybe some minor head work to the RB25 head.. then bolt together hopefully myself and into the car, again, hopefully myself. stick at the back of that an RB25DET gearbox and twin plate i guess. Yes - big asks ! :) If not, somebody else can do the assembly/fitting but i'd prefer to save as much as possible.
hopefully have one of the fastest RWD out there (in QLD anyhow)
Yeah, scared the crap outer me when I first saw the big oil slick under the car, quickly identified it though as the Gemini has done a similar thing just not quite as spectacular. Gavin was quite impressed by the amount of oil completly covering the underside of the car, and the oil stink from the oil burning on the exhaust.
.. next time i've been thinking a bit more of going more as to what i can afford as i get the cash.. so piece by piece on a fairly cheap car to start.
Rather than having the expensive car to start with and then having to pay for mods ontop of that (what i've found with the 33)
sr20.. yeah.. could be done :)
not a huge fan of the 4's though.. don't like an engine screaming its head off for the power..
hence the rb30det .. and no wanting an rb20det at any cost (revs too high to get power, snap/snap on and off)
anyhow, this work i'm doing in the background is shitting me right up the wall.. better iron out the bugs coz i wanna sleep now :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
