  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
maybe a chaser (or GTR really!) later on though.. i need some capital.
yeah.. the drag GTR are nutz.. i'd be happy with 12's to start. .. it'll just be the cost of the turbo to get any lower that will be prohibitive
Just turning the key in a GTR is expensive!!!!!!!!!!
A chaser would be the goods, seen a few nice examples in mags, have a more classy look with the serious hp potential.
yeah.. dey cool. .only prob i was thinking when i thought about it.. 1jz-gte parts are available and things.. but the other crap like bodykits and just accessories like suspension, etc = very rare in australia.. basically every little thing would have to come from jap.. which would be cool - but add up into expensive car over time. But hell it would be original and cool :)
2 more drawings to finish and i can call it a day, a very very long day. lol
MMMMM agreed, just finished doing a whole bunch of calcs for kerb offsets, sewer and stormwater lines. Just killing a bit of time while the brain unwinds. Then I have to get up at 6am and do it all again. Cool!!!!
Im back :)
All i can say is WOW!!
I did a highway run at .95bar and she pulls like a mother****er!
Perfect all the way to redline, no missing or problems at all.
Today i gapped my iridiums to about .7-8, they were 1.1mm, taped up the coil packs while i had them out, this really does work! And i also put catch can on :)
Thats adding to the trust ic and avcr i put on the other day hehe
Avcr is amazing, ive used them before, but never personally with my own car, the boost control is amazing, it holds whatever i set and holds it perfect.
Boost is stronger and faster down low and when changing gears on boost, there is 0 lag.
adrenelin is pumping :headspin:
Im back :)
nice!!
Thanks, first proper performance mods ive done to the car :)
Next is tyres, all 4 of them :)
Then its all uphill, Ces split dump+front, Hiflow, safc+sitc tuning etc
the it will haul
Just adding the recent stuff has brought a smile back to my face :aroused:
My dads gone overseas with the digital camera too :D otherwise ide have some nice photoshoots to show off the new equipment
the it will haul
yea i cant wait till i have some money to add cooler and highflow turbo etc into the equation
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
