  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly.. the car of course... The lil nagging problem I had wif the HICAS light and the rattling noises is become all too frequent and its damn annoying..
Just got a call from my mechanic, he's organising a data stream to see what exactly is wrong..  HICAS sensors apparently is not covered under my warranty.. but ABS is ... grrr.. not happy at all..
Hrmm.. guess the bright side is that a friend of mine is going to help me get some insulation into the doors and also fix the creaking that I have had on the passenger door for a while.
Whats wrong with your car dude? :D
Nexus.. I heard something about his wife taking over 75% of everything he owns and the shop was shut ?  I might have got it all wrong... thats why I wanted to see if you guys/grls know anything about it. :)
I THINK THAT MY PERSONAL LIFE HAS NOTHING TO DO WITH YOU OK
THE INFO YOU HAVE HEARD IS BULLSHIT.
SO SHUT YOUR MOUTH PLEASE - OR MY SOLICITOR MIGHT DO IT FOR YOU.
Yeah...  She may just come in here and set the story straight :headspin:
NO I WILL THANKYOU
GAVIN WOOD AUTO TECH IS NOT CLOSING DOWN AND NEVER WILL OK
I AM BUILDING THE BUSINESS TO GIVE TO MY 2 BOYS WHEN THEY GROW UP
THEY ARE ALREADY FOLLOWING DADS FOOTSTEPS WITH REGARD TO
MOTOR RACING
IF ANYONE HAS ANY QUERIES OR DOUBTS - PLEASE DONT HESITATE
TO CONTACT ME ON 0417760278
I WILL BE MORE THAN HAPPY TO SET THE STORY STRAIGHT
IT SEEMS TO ME THAT A LOT OF PEOPLE ON THIS SITE HAVE NOTHING BETTER
TO DO THAN BAG SOMEONE ELSES LIFE - THAT TO ME IS VERY SAD
GET A LIFE PEOPLE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GAVIN WOOD.
Not at work, the time over on the island was awesome, had a great time, but too much exercise for me, did more exercise in the last 3 days than I have in the last 3 years, so still a bit stiff and sore, got a raging head cold which is why I decided to call in sick :D
i think somebody wanted to set some rumours straight.. fair enough i guess..
Please PM WTF that was all about plz?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
