  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
tell me people how do uni students afford skylines and shit??? i work 36hours a week to get a crappy pay :rant: yet uni students seem to have more money and can do up there cars also :| drives me insane. damn this government.
dont worry im having a bitching day about my wage ;) its gay and will be gay when i finish apprenticeship. bank wont even give me a big enough loan to buy a house when i finish apprenticeship :) **** them time for suicide bombing is here, take down as many rich ****s as possible
Brings back memories of driving to QUT gardens point, in the "Devil Yellow" 998cc mini. Those were the days. Good things come to those who wait. I didn't get out of driving minis and geminis till I was 24, but now, I am a very happy little boy. Patience. You will enjoy it much better when you can go out and pay cash for the car you always wanted. Its a sweet feeling.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
