  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hello every one.
It was damn cold in Ipswich at 6:50am, I had Jeans, long sleeve shirt, jumper, jacket and benie and was still freezing.
Hey Gordo, that was quick.  Gives me hope for mine when I put it up for sale in a couple months.  Now the search for a replacement begins!
try being in yatala at 5:30 thats cold
jl i beat your quater time too :cheers:
too bad ur car has much more potential than mine
Don't worry James, I have a full exhaust in the mail at the moment. That, a new clutch and removing the boost restrictors should give me a 12 without too much drama :wassup:
Hey, I lived in Ormeau for 3 years. I had to leave at 4:50am to go to work when I lived out there. Luckily I had two big reverse cycle air-con units when I was out there. Ipswich is still colder though.
I have been hearing alot about these guys lately, seems to be very reasonably priced and appears to be doing a very good job from the 4 cars I have seen from his shop.
He's my repairer, we were just trying to get different quotes to compare pricings. But yeah, no one would give me prices :cheers:
I've seen a few cars come out of there and all VERY well done. I had a choice of him or Cameron from Camerons Body Works and I chose Shawn because he seems a lot more interested in helping you and giving you different ideas, not just for the money, but for what outcome you want. He can give you different options with paint and prices as well.
I was recommened to go there by Ben and Moi (owns the little purple ET, used to have the plates FUL11).
Plus Neil and Ross have been there and yeah, the results speak for themselves. Top bloke as well.
