  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if u want a loud car run, no cat, no muffler just 3inch from dumppipe :) hehe damn loud but sounds awsome :D hearing the turbo spool down and shit :D awsome :D:D:D:D:D
haha yea its funny 3.5" pipe is just rediculous lol....but kinda louder than what the rta restictions allow..if only everything was legal.
