  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Beau go for drive yeh??? :D
Hell yeah , after the Super fast Sunday cruise *sarcasim* I need a little fun , something of 25km/h ( no-offence pred , was a honour to be one of the last ppeps to ride in the beast before she left us) , but I think we should move somewhere else to continue this covo.
Just having a boring day.
You know how when you have something REALLY exciting coming up, the days seem to go slower? And the clock feels like it's been wound back a few thousand seconds :D
i hear ya erin
ive got next week off and this week is going so frickin slow!
just out of curiosity has anyone read this whole thread coz god damn there are alot of posts in it
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
