  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah i thought that, its just for a joke though. i dont mind 53XED like as in my car is SEXED up.
I havent seen your car at toowong in ages erin, you still work around there.
I don't work there anymore. They were a bunch of arseholes. Upthemselves cows who loved their dyson vaccuum cleaners (I've got my payment summary now, i can say that :))
I work at Bulimba now. Better working environment, closer to home, more flexible, more money.
Hay peeps , won't be here for long , gotta catch the train to the coast :wavey:
No-one here will be seeing the new beast until SAU QLD opening day , so you are all just going to have to wait .
I don't think I could afford the type of toys you'd wanna buy :Oops:
Andrew wants simple stuff like a wallet and a stein mug thing...
You want HUGE plasma tv's and stuff :(
You can pay things off you know
:) waiting game sucks..
now i am probably going to have to go through it all for another car.. I just can't wait for the endless delays, the endless excuses and everything else. oh hum.
But at least I have another payday now , might have enough cash left over to get gavin or someone to put the T/T & Profec on and have it tuned , so it's drivable for the day and for the skid pan.
would have liked to have the I/C on by then , but probably not ??
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
