  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I mean 12 months interest free on a $8k plasma would only be what.. $800 a month?
and you don't have to worry about paying for it for another 12 months! plenty of time to leave the country.. rob a bank, etc :(
:werd:
im supposed to be going for a beer with some mates this arvo but im quite comfortable sittin right here. had a huge week, im too buggered to drink beers atm. gotta drive to the sunny coast tomorrow too. will be a good fuel economy test :)
